March 12, 2021 at 3:50 pm
Shin-Sung Kim
Ansys EmployeeMeasuring the power radiated by a dipole source requires special considerations, especially when the dipole is placed in a dispersive material with a non-zero imaginary part of the refractive index.nThe issue of using dipoles in a dispersive material is a theoretical issue, rather than a numerical issue. In dispersive materials, the imaginary part of the Green's function begins to diverge, leading to infinite amounts of power. Here are two possible ways to deal with this issue in FDTD:nCreate a small volume of dielectric material right near the dipole location (maybe 5 mesh cells in size). This avoids the entire problem since the dipole is not located in a dispersive material. You can then use the dipole power function or monitor box to measure the radiated power. When using the dielectric material, set the real part of the refractive index to be matched with the surrounding lossy material. Obviously, this works better with single frequency or narrow band simulations due to the dispersive nature of the surrounding material. Also, make sure to set the correct mesh order for the dielectric.nPlace the dipole within the dispersive material as you want and use the transmission box to measure the power (don?t use the dipolepower). The box should have some finite size (minimum ~5 mesh cells). You will be able to measure the amount of power radiated out of that box, but you will not have information about power absorbed within this box, which might make this approach less suitable for highly lossy materials.n
Simulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- Error on Lumerical device
- Lumerical support has moved to the Ansys Learning Forum (ALF)
- focusing efficiency
- How to perform optimization over terminal in linux without GUI?
567
532
220
172
116
© 2022 Copyright ANSYS, Inc. All rights reserved.
