March 13, 2021 at 12:15 am
Kyle
Ansys EmployeeThis page describes three different methods for measuring reflectance from a structure.
- Using a monitor placed behind the source is the common and simplest method.
- Placing the monitor in front of the source can improve the accuracy in situations where there are source injection errors.
- We also discuss an alternative technique using a monitor placed along the source injection axis.
Viewing 0 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2656
2120
1347
1118
461
