April 23, 2021 at 9:35 pm
Lito Yap
Ansys EmployeeSetting the cores to use when running Lumerical Multiphysics simulations. By default, Multiphysics solvers; CHARGE, HEAT, FEEM, DGTD and MQW will run the simulation job using all available cores/threads on your machine. The core count can be changed in your simulation.
- Open your project/simulation file.
- Select the "Solver and Edit object".
- Navigate to the Advanced tab.
- From the multithreading drop down option, choose 'set thread count'.
- Enter the number of threads or use the up/down arrow to change the number.
See also: Lumerical solver, accelerator and Ansys HPC license consumption
Simulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- Workbench not opening
- Workbench error
- License Error
- Licensing Error
- Error with lumerical license activation.
- ANSYS 19.1 installation on Linux
613
562
220
188
128
© 2022 Copyright ANSYS, Inc. All rights reserved.
