March 13, 2021 at 12:40 am
Kyle
Ansys EmployeeIn some situations, you might see a negative Q-factor, and this is obviously wrong. This post discuss one possible reason that can cause a false Q value from a simulation.
High Q cavities
If this is a high Q cavity, light can be trapped within the cavity for a long time. As a results, it is not very efficient to wait for the simulation to finish and take the ratio of the resonant frequency and delta_f. Instead, we use another approach to look at a portion of the decaying signal to find Q.
Viewing 0 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2518
2064
1279
1094
456
