March 15, 2021 at 9:25 am
Greg Baethge
Ansys EmployeeThe 2D surface conductivity model of graphene used in Lumerical’s optical solvers (FDTD and MODE) requires the user to specify the scattering rate for graphene in units of energy (eV), which is a common way to quote this parameter in the literature.
Viewing 0 reply threads- You must be logged in to reply to this topic.
Ansys Innovation SpaceSimulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- Error on Lumerical device
- Lumerical support has moved to the Ansys Learning Forum (ALF)
- focusing efficiency
- How to perform optimization over terminal in linux without GUI?
613
562
220
188
128
Top Rated Tags© 2022 Copyright ANSYS, Inc. All rights reserved.
