March 16, 2021 at 5:46 am
Khashayar Ghaffari
Ansys EmployeeIs it possible to do a 2D simulation in FDTD Solutions on a plane other than the default XY plane?
By default, the FDTD solver only has 2D setting on the XY plane. That said, there are some ways to set up a quasi-2D simulation in a 3D FDTD solver, say on the XZ plane with the memory requirement on the scale of a 2D simulation.
The trick is make a 3D simulation region with a one-mesh-cell thick y span. Like this screenshot below:
Viewing 0 reply threads- You must be logged in to reply to this topic.
Ansys Innovation SpaceSimulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- Error on Lumerical device
- Lumerical support has moved to the Ansys Learning Forum (ALF)
- focusing efficiency
- How to perform optimization over terminal in linux without GUI?
613
562
220
188
128
Top Rated Tags© 2022 Copyright ANSYS, Inc. All rights reserved.
