March 10, 2021 at 12:14 pm
Greg Baethge
Ansys EmployeeThis topic describes the CW normalization used to convert time domain data to frequency (steady-state) data. The CW normalization option should be used whenever you collect frequency domain information.
Solvers: FDTD, varFDTD
See also:
Frequency domain normalization
Single frequency simulations in FDTD
Sources in FDTD always inject a pulse (i.e. broadband), even when the user is only interested in collecting data at a single frequency. Pulse sources are more efficient for collecting broadband information, and at least as efficient when collecting information at a single frequency. Therefore, there is no reason to use CW sources. The CW response of a structure can easily be obtained from a simulation that used a pulse source.
The following screenshot shows the source Frequency/Wavelength settings tab. In this screenshot, the source wavelength is set to a single frequency of 500nm. Even thought the frequency span is zero, a pulse is still used. The time domain signal of the pulse, and the associated power spectrum, are shown in the figures on the right side of the window.
Viewing 0 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2614
2088
1321
1108
459
