March 15, 2021 at 10:35 am
Greg Baethge
Ansys EmployeeAlthough time domain simulation method is able to return broadband results, we still would want to run single frequency simulations in some situations to obtain a full spectrum. We have a built in parameter sweep GUI tool for this purpose, or users can always choose to make use some script commands to achieve this. No matter which way the sweep is done, there are several tips to improve the smoothness of a spectrum.
FDTD and varFDTD
In FDTD and varFDTD, there is a setting in the Advanced options tab in the Edit simulation window, like this screenshot below. This can make sure the material fit and mesh generation are in a good shape for the sweep.
Viewing 0 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2620
2098
1327
1110
461
