Photonics
Photonics
Ansys Insight : Using the non-uniform mesh (periodic structures)
    • Greg Baethge
      The non-uniform mesh generation does not necessarily produce meshes that automatically match the periodicity of the physical structure. In some cases, such as high Q photonic crystal micro-cavities, using a mesh that has the same periodicity as the physical structure being simulated is better for numerical accuracy. In this case, a mesh override region can be used to ensure that a/Δ=N
      where a is the period, Δ is the mesh cell size and N is an integer.
      To insert mesh override regions, select the Mesh option of the Simulation button.
Viewing 0 reply threads
