February 12, 2021 at 12:10 am
Taylor Robertson
Ansys EmployeeTo create a movie of the CW response we have a feature called the phase shift animation.
- Select the E, H or P result.
- Visualize one of the components X, Y, or Z.
- Open the figure settings and scroll to the bottom. Enable the “Phase shift animation”
- Set the FPS frames per second, and frames per cycle, I find that 32 frames per cycle and 25 fps works well.
- Export as an .mpeg or .avi movie.
Viewing 0 reply threads- You must be logged in to reply to this topic.
Trending discussions- Why am I getting “process exited without calling finalize”, and how do I fix it?
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5454
3419
2473
1310
1022
