February 23, 2022 at 11:25 am
Evka
Subscriber$begin 'General Info'
ProductName='ANSYS® Electromagnetics Student '
BuildInfo='Release 2021 R2 (Build: 2021-06-02 22:21:55)'
ExeInfo='Executing from C:\Program Files\AnsysEM\Ansys Student\v212\Win64\ansysedtsv.exe'
$end 'General Info'
$begin 'Installed Components'
$end 'Installed Components'
$begin 'License Info'
FlexlmVersion='2021.0512'
AdminDir=''
CustomerNumber='-1'
LicenseFiles('\ansyslmd.ini')
ActiveServers()
ActiveHostIds()
Provider='ANSYS Common Licensing'
'ANSYSLI Version'='2.2.1'
$end 'License Info'
February 23, 2022 at 11:31 amFebruary 23, 2022 at 11:33 amEvka
SubscriberWhen I click on diagnose it shows like this
BuildInfo='Release 2021 R2(Build: 2021-06-02 22:21:55)'
ExeInfo='Executing from C:\\Program Files\\AnsysEM\\Ansys Student\\v212\\Win64\\ansysedtsv.exe'
$end 'General Info'
AdminDir=''
CustomerNumber='-1'
LicenseFiles('\\ansyslmd.ini')
ActiveServers ActiveHostIds Provider='ANSYS Common Licensing'
$end 'License Info'
February 23, 2022 at 11:46 amEvka
SubscriberAfter installation, It had shown "configure this machine.exe failed with error code 1:"
February 25, 2022 at 6:37 pmGeorge Karnos
Ansys EmployeeI would recommend to open an elevated CMD and run the following:
del /Q "%TEMP%\configurethismachine.*"
del /Q /A:H "%TEMP%\configurethismachine.*"
"C:\Program Files\AnsysEM\v221\Win64\config\ConfigureThisMachine.exe" -v -v --uninstall -i "C:\Program Files\AnsysEM\v221\Win64" --redirect-file c:\temp\ctmuninst.log
....wait a few minutes.....
"C:\Program Files\AnsysEM\v221\Win64\config\ConfigureThisMachine.exe" -v -v -i "C:\Program Files\AnsysEM\v221\Win64" --redirect-file c:\temp\ctminst.log
check the contents of the c:\temp\ctminst.log and c:\temp\ctmuninst.log
If seeing error, then uninstall all the Microsoft VC++ and manually install each one from AEDT install media.
There are other posts on here to that may have ideas.
search for:
Configurethismachine
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2656
2120
1345
1118
461
