February 3, 2022 at 2:48 pm
Rwinton
SubscriberFebruary 8, 2022 at 9:35 pmANSYS_MMadore
Ansys EmployeePlease share complete text of the error you are encountering.
February 9, 2022 at 2:11 pmRwinton
SubscriberThat message is the only thing that appears on the startup of the application.
February 9, 2022 at 4:15 pmANSYS_MMadore
Ansys EmployeeWhat you need to do is launch the Client Licensing Settings utility, making sure to use right-click -> run as administrator. Then you can enter the right license server information in the form and hit Save. See if that helps.
Trending discussions- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5290
3311
2469
