Ansys Products
Ansys Products
ANSYS LICENSE MANAGER ERROR
    • dfjnn
    • ANSYS_MMadore
      Array This message is telling you that all of the licenses are currently in use. Someone would need to exit ANSYS to allow you access to the license.nYou may confirm the users by running this command:nC:\Program Files\Ansys Inc\Shared Files\Licensing\winx64\lmutil lmstat -a -c 1055@TSUCHIYA_ANSYS2nnThanksnMattn
    • dfjnn
      Matt, nActually, there are about 5 PCs connected to the server PC. I tried to restart the PC I'm using, the server PC, and the other 2 PCs. Then somehow by doing that, the software in the PC I'm using could be used again. Also, the script error 800a01a8 could be fixed by deleting the v15 folder. But, the software in the other PCs are still not functioning well. The analysis system button does not appear on the left table. For the time being, I'll just focus on the final year research project given to me... Maybe tomorrow I will confirm the number of users by running the command in the server PC.nThank you so much!nEdifn
