November 17, 2021 at 9:37 am
slawomir.lagowski
SubscriberMy Customer has SpaceClaim R2 (PU + TECS). He can open SpaceClaim using shortcut on the descktop without any problems. He can design and save his job. But when he try to open file with doubleclick on it (*.scdoc) he gets every time: Failover feature 'Ansys SpaceClaim Direct Modeler' is not available. No valid FLEXLM servers specified. What can be wrong with his license? Slawomir
November 17, 2021 at 11:15 am
Devendra Badgujar
Ansys EmployeeHi Slawomir This is a known issue that we have came across and a bug ticket has been filed ( 367451 ) for that. I will check with the developers for the update on this and will let you know soon. Please go through this post double click on .scdoc 2020R2 - Questions - Ansys Discovery Forum and see if it solves the issue. Regards. -
November 19, 2021 at 8:34 am
Devendra Badgujar
The registry key value should be set to the following:
"C:Program FilesANSYS Incv195scdmspaceclaim.exe" "%1" "/USERUNNINGSPACECLAIM=true" /UseLicenseMode=true
/UseLicenseMode=true is necessary to make Discovery SpaceClaim look for the subscription license. Without that set it will look for a floating license, which is why they get the error in the image you submitted.
Please let me know if this resolves your issue.
November 19, 2021 at 9:11 am
slawomir.lagowski
SubscriberHi Devendra Badgujar
Customer just changed registry key, restart Windows and still same problem.
He changed following key: "C:Program FilesANSYS Incv212scdmspaceclaim.exe" "%1" "/USERUNNINGSPACECLAIM=true" /UseLicenseMode=true
November 19, 2021 at 9:29 am
Devendra Badgujar
Please can you send the SpaceClaim log from '%APPDATA%SpaceClaimLog files' and the Ansys license log from %TMP%.ansys of the customer on ansys-discovery-support@ansys.com.
November 29, 2021 at 1:15 pm
Devendra Badgujar
I am checking with the development team for more information on this, I will update you as I hear from them about this issue.
Regards.
- Can’t see license on online account
- loss of user settings
- Copy user settings to new release
- help online
- Unexpected graphics error
- Electric Heating – Ansys AIM
- Dwg export error
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
3744
2573
1793
1236
594
