May 10, 2023 at 10:37 am
May 10, 2023 at 12:39 pm
Vijay
Ansys EmployeeIt looks like all the Mechanical Enterprise licenses available on the license server are in use. If someone closes the application and a free license is available, you should be able to open Mechanical.
May 11, 2023 at 12:58 am
Abuzar Jamil
SubscriberThank you for your response. But I was the only one using it at that time. I also got this error message below when I tried to open ACP Pre.
"Specified Material DB path (C:\Program Files\ANSYS Inc\ANSYS Student\v222\ACP\databases\materials.acpMdb) does not exist!"
I recently installed this licensed version It works fine when I edit the engineering data, use space-clam, mechanical model, and ACP pre. But it gives me the error when I try to open the static structural module.
May 11, 2023 at 2:15 pm
Vijay
Ansys EmployeeIs the license locally installed on your machine?
Can you launch Mechanical and go to File > Licenses > click Reset to Default and try rerunning the simulation?
May 12, 2023 at 3:22 am
Abuzar Jamil
SubscriberIt works fine now. Thank you for your response.
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5242
3299
2469
