August 19, 2019 at 11:07 am
aaturani
SubscriberHi every one,
I have a problem when I'm trying to couple SolidWorks and electromagnetic suite via the workbench.
I import SLDpart in Geometry in workbench and connect it with Maxwell 3D. but when I run the maxwell setup, this error appears and I cant couple this tow.
Ansys License Manager Error, No server Provided, ANSYSLI_SERVERS: FLEXlm Server:
the point is when I import step files in geometry, this error doesn't appear and just appear when I import SLDpart.
Both Ansys workbench and Electronic suite versions are 19.1
I would be so thankful if anyone could help me with this problem.
- Maxwell, HFSS or Q3D?
- Error
2564
2080
1299
1106
459
