Ansys Products
Ansys Products
ANSYS License Manager Error: System clock has been set back
    • Lucasax98
      I'm a student and I've installed ANSYS 2020 R1 but every time I try to open the geometry editor this error message appears:
      I've found this topic: https://studentcommunity.ansys.com/thread/license-manager-error-aa_t_i/   that match with my problem. So i tried to locate the files that have a future date and I found a lot of them (hundreds of files with creation date in 2064, I have no idea where they come from), but I don't know how to change their dates. I tried using a tool but it doesn't work, also because many of them are system/windows files and I can't even delete them. I also tried to change manually the date on windows but I guess I made things worse because now I have other new files with a future date. Any suggestion?
      Thank you
    • tsiriaks
       Thank you for checking the past thread.
      This is exactly the cause of the licensing issue you are having. Unfortunately, until you can make those files to not be in the future date compared to your systems clock, the licensing won't work.
      The fact that you can also, somehow, easily create new files with future date is concerning. I think it may be best you reformat the machine. If you want to explore other options, your best shot would be to ask Microsoft experts in their forum.
    • Lucasax98
      Thank you I think I will try directly to reformat my pc next week and I will try again. I will let you know if there are other issues.
    • tsiriaks
      Sounds good. Please report back how it goes. You may also need to verify that the installation package that you use to install your OS is valid and no issue/virus.
    • Lucasax98
      I've reformat my pc and now it's working, I think that's the only solution to this problem if you can't modify those files
    • tsiriaks
      Thank you for the update.
      I'm glad that reformatting the machine helps with you Windows system files having future date issue
    • Fum4sz4
      After a lot of searching, I finally managed to find a solution to my problem.nI installed the Attribute Changer for Win10, researched all the softwares of my system that use the FlexNet system, forced the closing of all the operations by the Task Manager. I did the search in C:by date and specified the interval from 09/22/2020 - 01/02/2021. I organized by Modification Date and selected all files and folders that had a date after the current date (09/22). I followed this tutorial:https://www.online-tech-tips.com/computer-tips/how-to-change-the-last-modified-date-creation-date-and-last-accessed-date-for-files-and-folders/#:~:text=File%20Properties%20tab.-,If%20you%20want%20to%20change%20the%20last%20modified%20date%20or,these%20using%20the%20options%20providednIn case the use of external links is not allowed, I apologize, but it was the only solution I could find.n
    • tsiriaks
      Thank you for sharing your resolution @Fum4sz4nn
    • njkr224
      I have this same problem but cant fine any files with a future date. i have also checked my system clock and it is fine and set properly. Any suggestions? i saw that reformatting my PC will work but i am trying to avoid that. Thank for your help in advancen
    • tsiriaks
      how far in the future that you check the files ?nyou can try extending to 3000 or even 9999 if you still can't find any filen
    • njkr224
      I checked as far as my system can on my C drive. I needed to get the program working by today for class work. i ended up having to do a clean install of Windows to fix it. Thank you for your response though!n
    • tsiriaks
      I see. Thanks for the update.n
Viewing 11 reply threads
