Ansys Products
Ansys Products
Ansys License manager it does not start
    • mousa
      It was working since I deployed it two months ago and today I’m not able the licncse manager stopped and when I try to start the license manager it does not run with below messages.
      Licensing Interconnect: not running
      Licensing Interconnect Monitor: not running
      FlexNet Licensing: not running
      Then when I run “View licensing Interconnect log I got
      -------------------------------------------- NORMAL STARTUP 2023/10/05 16:21:28 ---------------------------------------Ansys Licensing Interconnect version 2022.2.0 (20220519) for winx64.  Updated at Ansys Release 2022 R2.  Started on 2023/10/05 16:21:28 by SYSTEM@lserver-p3.iltech.iit.edu:winx64 with pid 9504.
                                      (C) 2022 ANSYS, Inc.  Unauthorized use, distribution, or duplication is prohibited.
                                      Built Using FlexNet Publisher v11.16.4.0 build 252457 x64_n6
                                      Built Using OpenSSL 1.1.1n  15 Mar 2022
                      Please note that entries in this debug log have the following format:
      TIMESTAMP              ACTION              FEATURE                    REVISION (BUILD DATE)             A/B/C/D                 W/X/Y/Z   PID:MPID:APP:USER@HOST:PLATFORM:DISPLAY                                    SOCKET:IP
                                      Licenses statistics:
                                      A is the number of licenses requested by this ACTION.
                                      B is the number of licenses used by this USER.
                                      C is the number of licenses used by all users.
                                      D is the number of licenses available in the local license pool.
                                      License server performance statistics:
                                      W is the number of currently connected client applications.
                                      X is the maximum number of connected client applications.
                                      Y is the unique serial number of this client application.
                                      Z is the number of all client applications served by this Licensing Interconnect server.
      2023/10/05 16:21:28    INFO                ANSYSLI_CMD=C:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64\ansysli_server.exe -nodaemon
      2023/10/05 16:21:28    INFO                ANSYSLI_INITIALIZATION_FILE=No initialization file found.
      2023/10/05 16:21:28    INFO                ANSYSLI_MONITOR=C:\Program Files\ANSYS Inc\Shared Files\Licensing\winx64\ansysli_monitor.exe
      2023/10/05 16:21:28    INFO                ANSYSLI_PRODORD_FILE='C:\Program Files\ANSYS Inc\Shared Files\Licensing\prodord\ansysli.prodord.xml'
      2023/10/05 16:21:28    INFO                FLEXLM_LICENSE_FILE='C:\Program Files\ANSYS Inc\Shared Files\Licensing\license_files'
      2023/10/05 16:21:28    INFO                ANSYSLI_PORT=2325
      2023/10/05 16:21:28    ERROR               No features to serve, ansyslmd shutting down.
      2023/10/05 16:21:28    ERROR               FLEXlm server is down with no available features to serve. Please correct license file and re-start daemons.
      2023/10/05 16:21:28    ERROR               Could not start FLEXlm server. Exiting.
      2023/10/05 16:21:28    INFO                Listen Socket Created
      2023/10/05 16:21:38    INFO                Windows service stopped.
                                      -------------------------------------------- NORMAL STARTUP 2023/10/05 16:26:13 ------------------
                                      Ansys Licensing Interconnect version 2022.2.0 (20220519) for winx64.  Updated at Ansys Release 2022 R2.  Started on 2023/10/05 16:26:13 by SYSTEM@lserver-p3.iltech.iit.edu:winx64 with pid 12784.
      And the under Diaggnostic à Diplay FlexNet licncse status Igot
      lmutil - Copyright (c) 1989-2015 Flexera Software LLC. All Rights Reserved.
      Flexible License Manager status on Thu 10/5/2023 23:16
      [Detecting lmgrd processes...]
      Error getting status: License server machine is down or not responding. (-96,491)
      Please I need your help.
      Thanks,
    • Mrunali Barde
      Greetings,
      Can you please check if the updated license file is present on the Ansys license server? Can you also confirm the expiry date and server details?
