October 15, 2018 at 8:56 pm
tyrone
SubscriberMy ansys 19.1 license server (Winsvr2016 std 64bit) is denying access to workbench and fluent clients intermittently. Please analyze the log files and determine if the server licenses are being exhausted by client requests, or whether one user is hogging all of the licenses, or whether there is some software error.
October 15, 2018 at 9:24 pm
tsiriaks
On the license server machine, create a file named ansyslmd.ini under C:Program FilesANSYS IncShared FilesLicensing , then put the following in its content
ANSYSLI_TIMEOUT_FLEXLM=15
ANSYSLI_FNP_IP_ENV=1
ANSYSLI_FLEXLM_TIMEOUT_ENV=15000000
Then, restart the ANSYS License Manager.
If this doesn't help, ask the users that have this issue to add the same thing in ansyslmd.ini on their local machine.
It may also be worth checking whether these cadlab25.lsu.edu , cadlab25 , cadlab25.me.lsu.edu , resolve to the same IP address (from any client machine and the license server machine).
Thank you,
Win
October 16, 2018 at 4:13 pm
tyrone
Applied the suggested fix. Will see if users can connect.
Cadlab25, cadlab25.lsu.edu, cadlab25.me.lsu.edu all resolve to 96.125.112.206.
October 16, 2018 at 4:52 pm
tsiriaks
Ansys EmployeeSounds good.
Please do let us know how it goes.
Thank you,
Win
October 16, 2018 at 6:20 pm
tyrone
SubscriberI have a linux64 cluster client that you see as mike086 in my log files. The majority of the problem seems to occur from cluster users.
The cluster can resolve cadlab25.me.lsu.edu and cadlab25.lsu.edu correctly, but it cannot resolve the alias cadlab25 at all.
Windows clients can resolve all 3. Is this a problem for Ansys connections?
October 16, 2018 at 7:21 pm
tsiriaks
I think IP resolution may not be the issue at this time. But if you like to make sure, you can try changing the currently installed license files on the server
C:Program FilesANSYS IncShared FilesLicensinglicense_filesansoftd.lic
C:Program FilesANSYS IncShared FilesLicensinglicense_filesansyslmd.lic
so that it uses fqdn instead of hostnames (make sure you restart the ANSYS License Manager after this change)
Can you post the most recent logs (FlexNet Debug log and Licensing Interconnect), which include the failed attempts of mike086 ?
If the error message still has this "FLEXlm server is not responding. Resource temporarily not available." , please add the same thing in the ansylmd.ini file of the cluster (e.g.,
/ansys_inc/shared_files/licensing/ansyslmd.ini) .
Thank you,
Win
October 16, 2018 at 8:36 pm
tyrone
SubscriberI stopped the license server because I could not edit the .lic files while running. I tried to re-install the license files after
changing the CADLAB25 string to CADLAB25.me.lsu.edu in both files. I tried to add the apache license file, and the admin process gives me the error:
2018/10/16 15
4:00: Did not upload file - Error: A correctly-formatted VENDOR line was not found in the license file.
The vendor line reads: VENDOR apacheda. That's it. Only the SERVER line was modified. What is the problem now? Urgent: can't start the server again until this is resolved. I removed the .me.lsu.edu string - with no effect. Don't understand this.
October 16, 2018 at 8:40 pm
tyrone
SubscriberWhere do you attach files in this process?
October 16, 2018 at 10:13 pm
tsiriaks
Don't install license file for apache. That doesn't work with ANSYS License Manager. Just install the ones that say ansys or ansoft.
Thank you,
Win
October 17, 2018 at 4:00 pm
tyrone
SubscriberI upgraded the license manager to version 19.2. The cluster clients and windows clients are working now. Thanks.
October 17, 2018 at 4:28 pm
- Workbench error
- Workbench not opening
- License Error
2600
2086
1317
1108
459
