March 8, 2023 at 3:46 pm
Ash Curran
SubscriberHi all,
I would appreciate some guidance. I am using ANSYS LS-DYNA through workbench 2023 R1 and am trying to set up a bird strike simulation for a laminated aircraft window. In doing so i believe i need to specify the body interactions between the plies of the window as 'bonded'. When i do so, the following error comes up:
Can anybody point out where i am going wrong and how to move forward please?
Ash -
March 8, 2023 at 4:10 pm
Armin Abedini
SubscriberHi Ash,
Try defining contact pairs instead of body interactions: Right click on Contacts --> Insert --> Manual Contact Region
You can then select the target and contact surfaces and set contact type to Bonded. -
March 15, 2023 at 3:53 pm
Ash Curran
SubscriberThankyou! I seem to have sussed this out now.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3744
2573
1809
1236
594
