March 29, 2022 at 1:29 am
charey
SubscriberGreetings,
We are setting up our academic license on our server and hope that local clients can access the license on the server. We downloaded the license file through the licensing portal successfully. We can run the software without any problem on the server. However, the local clients cannot find the license. Here are the things we tried:
- set the 'ansyslmd' vendor daemon port to static port 1056: https://support.lumerical.com/hc/en-us/articles/4660658639251-License-server-configuration-and-license-file-installation
- Open the firewall for port 1055 and 1056 using the procedure here: https://docs.microsoft.com/en-us/sql/reporting-services/report-server/configure-a-firewall-for-report-server-access?view=sql-server-ver15
- Open the firewall for ANSYS license apps as shown here:
- Check whether the ports on the server is listening by entering netstat -na in powershell, the result is attached picture 1. The ports 1055 and 1056 are listening.
- Check the connection between local client with the lisence server with
- test-netconnection 128.95.196.91 -port 1055: The result is failed, as attached picture 2
- test-netconnection 128.95.196.91 The result is succeed
- These results indicate that the connection in 1055 and 1056 ports are still blocked. But we are not sure why that is the case, as we have opened the ports.
The error message is shown in figure 3. We noticed that there was a similar issue in a previous post https://forum.ansys.com/discussion/6792/client-machine-does-not-borrow-the-licences
but the detailed solution was not mentioned. Please advise how we should get the license to work. We are not attaching the license files. But if it's required we can upload it as well. Thanks a lot for your help!
March 29, 2022 at 1:02 pmLuis Silveira
Ansys EmployeeHello,
Make sure that you have the ports open inbound and outbound.
March 29, 2022 at 4:07 pmcharey
SubscriberHi Thanks for your comments. We have made sure both inbound and outbound rules are set and enabled on both server and local client. However, it is still not working. Are there any other suggestions?
Best Rui
March 29, 2022 at 4:15 pmcharey
SubscriberWould it be helpful if I post some of the license interconnect log here for you to check?
March 29, 2022 at 4:31 pmLuis Silveira
Ansys EmployeeYou will need to determine what is causing the Test-NetConnection xxx.xxx.xxx.xxx -Port 1055 to fail.
Your IT Team should be able to determine what is causing it.
Are you using another IP (external IP address) for the server?
Are the client machines, laptop or desktop computers?
Docking station used?
Are you connected to Wi-Fi or cable to the modem ?
Local Network connected, or remote and VPN used?
March 29, 2022 at 4:41 pmcharey
SubscriberHi Thanks for your questions.
The IP address is correct. This was verified by the fact that we can remote connect to the server using Windows Remote Connection. We also verified that on the server using ipconfig commend.
It could be any type. Right now I'm using a laptop with win 11 system.
I don't think so.
The server is connect via Ethernet cable. Client is via wi-fi. We are in the same local network.
Local Network
March 31, 2022 at 9:09 pmLito Yap
Ansys EmployeeIt looks like you are on a different network.
license server IP: 128.95.196.91
client/source IP: 10.18.203.112
Are you connected to the Wifi (Internet)? Can you check with IT how you can access the license server: 128.95.196.91 on TCP ports 1055 and 1056 from your computer: 10.18.203.112 via Wifi (internet) i.e. via VPN? Or connect the client computer via LAN ethernet cable - on the same network as the license server. Try to set the inbound rules on Windows as shown in this post.
Can you check the license server status from the client computer?
"C:\Program Files\Lumerical\v221\licensingclient\winx64\lmutil.exe" lmstat -c1055@128.95.196.91 -a -i
Viewing 6 reply threads- You must be logged in to reply to this topic.
Trending discussions- Error with workbench SceneGraphChart
- Workbench error
- Workbench not opening
- License Error
2600
2088
1319
1108
459
