Installation and Licensing
Q&A around getting started with Ansys software
ANSYS magnetostatic and ANSYS Maxwell
    • mohammedlaminemekhalfia
      Dear ANSYS users.
      I am trying to resolve the following physical problem. using ansys 2021 r1.
      Electromagnet that has a coil of 165 turns and 0.0031H and powered by 25 A (AC/DC pending on need) that attract and release a plate standing parallel to it as show in the following picture.
      I tried to use ANSYS magneto-static to represent the flux density and the force so I made the following structure
      Running ANSYS magneto-static result in fail due to the following error, despite of trying all the suggested solution yet I am still facing the same issue.
      I tried to switch to ansys maxwell but I could not run it as I had teh following error and for the same case I used all the suggested solution about the licence and nothing worked.
      Please advice
    • Ivonne Marti
      Hello Mohammed, In your last image, you are opening Maxwell from Workbench platform. I would suggest to open Maxwell standalone. To do this, please go to Windows icon and select Ansys EM Suite. Please also check that you have installed the last release of the Ansys License Manager (available in the Ansys Customer Portal), in this case 2023R1. If the Ansys License Manager is working correctly, then please uninstall Ansys EM Suite and install it again. When you do the installation, please pay attention in the step where you point to the license. I hope this helps you. Ivonne
        Thanks @Ivonne - I launched ANSYS maxwell both from workbench and standalone, and I have the same issue. I merged ansys Electronics with workbench to be able to perform magneto structural coupled simulation. so this why I thought that magnetostatic module will help me instead and it did not work too.
        I used ANSYS ELECTRONICS 2021 R1 as my workbench is ANSYS 2021 R1.
        I will try to use ansys 2023 instead as suggested and keep you informed.
        • Ivonne Marti
          Hello, You need the version 2023R1 of the Ansys License Manager. Please find below an image of this "tool".
          Thanks a lot for your assistance.
          well, Maxwell now is running both standalone and from workbench but.....magnetostatic is still having the error
        magnetostatic is still having the error.
        05 mceclip1
        05 mceclip2
        • Vijay
          Can you try the suggestion in this post to see if it helps ? https://forum.ansys.com/forums/topic/how-do-i-solve-this-error-in-magnetostatic-analysis-in-ansys/
