September 7, 2018 at 7:48 pm
radhikaiyer
SubscriberI am trying to simulate an axially polarized Neodymiun N42 ring magnet (3 in O.D., 2 in I.D., 0.5 in thickness) in Ansys Workbench. As a result, I want to see the magnetic field lines generated by the magnet and field intensity on the surface and around it. The medium is air. I am expecting the field intensity to be symmetric but somehow I am not getting the expected results. I don't know if my polarization direction is wrong. I just want a validation for my results. Below are the images of Polarization and Field lines that I obtained.
Thank you,
Radhika
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1283
1096
459
