Ansys Products
Ansys Products
ANSYS Materials Library
    • Henri Lu Cas
      Hi Ansys,
      Anyone knows here how to import a materials library? We have our own materials library and its tedious to do it by using the "Add Material" and typing the materials name etc. one by one.
      Thnaks,
      Henri
    • Ram Gopisetti
      Hi we (ANSYS) support xml file, so if you could check the xml file of sample libray you can parse the database into our xml format.
      Cheers, Ram
    • Mike Rife
      Hi Henri
      In the lower right of the UI you posted is a 'Export to Library' option.  You can create your materials then export them to a library.  Then next time it will show up as a personal library in the upper right (if saved to your personal location).
      Ram & Henri - Maxwell uses a library format similar to XML but is not XML.
