September 7, 2023 at 1:34 pm
September 8, 2023 at 9:00 am
Timos
Ansys EmployeeHello, the speed graph does not start from zero because on Mechanical Tab inside MotionSetup the Angular Velocity is set to be the value you see on rpm. In your case the Band of your rotating part will rotate with the adjusted Angular Velocity.
In order to obtain more information, please visit : Maxwell Help > Setting Up Motion for Transient Projects > Assigning a Band of Motion
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7592
4440
2953
1427
1322
