June 11, 2020 at 12:41 pm
congmin
SubscriberThe heat generated by maxwell is opposite to the temperature distribution curve
strange
Going out specific heat capacity convection conditions and other issues, making them contrary, is it possible that I have made a mistake in setting the conditions in the steady state thermal module operation
If so, can you tell me, what are the possible conditions?
Thanks -
June 17, 2020 at 7:20 pm
Karthik R
AdministratorThis question has been answered in a different thread. Here is the link.
https://forum.ansys.com/forums/topic/maxwell-and-steady-state-thermal-2/
Best,
Karthik
June 29, 2020 at 8:13 am
congmin
SubscriberIn the steady-state thermal module, the result is that the workpiece is heated to about 600 degrees. I then went to the transient thermal module to analyze and found that after 600 degrees, the workpiece still heats up. Where does the problem cause this?
July 11, 2020 at 6:19 pm
July 23, 2020 at 12:52 pm
congmin
Subscriberhi Kreemella
I have new question about Steady state thermal,can you this link see and answer
https://forum.ansys.com/forums/topic/maxwel-loss-imported-value-to-steady-state-thermal/
thank you
congmin
- Maxwell, HFSS or Q3D?
- Error
3930
2649
1861
1272
610
