August 23, 2023 at 7:23 am
August 24, 2023 at 7:48 pm
Vedant Sane
SubscriberHey, I am working on similar topic. I might help. Could you able to send me your model?
August 25, 2023 at 3:08 pm
HDLI
Ansys EmployeeHello All,
Please find an example for PM motor in "C:\Program Files\AnsysEM\v232\Win64\Examples\Twin Builder\Applications\PowerSystem\PMSM_SpeedControl_EMI.aedt".
You could use torque component, mass or generator as a load. You may need to use speed control and keep exciation' frequency is synced with speed in the model.
HDLI
August 30, 2023 at 1:00 am
sampathkumar
SubscriberHi vedant....thanks for the information....can I have your email details
August 30, 2023 at 9:24 am
Vedant Sane
Subscribervedant.sane@outlook.com :D
September 4, 2023 at 8:52 am
sampathkumar
SubscriberHi....
I need to include damping coefficient to the simulation setup...Can anyone please suggest me how to connect damping
September 18, 2023 at 7:53 am
Vedant Sane
SubscriberHi Sampathkumar,
In mechanical library you will find the damper which you can then connect to your motor model. Have you already shared your model with me? I did not received your email.
Thanks!
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7742
4502
2961
1449
1322
