Installation and Licensing
Q&A around getting started with Ansys software
ansys maxwell error – closing file 1%
    • Bradley Henry
      I am using a system with 16 cores, 512GB RAM. For some reason it throws this error at a way lower memory usage. I was trying just using 8 cores in this photo, but the error is thrown at the same for 16 cores. I can't figure out why this is happening.
    • Timos
      Hello, this error message typically relates to an issue with disk space on the machine you've used to solve the model. It appears when there is low disk space.Can you check the drives on the machine you've used and see if they are full or close to being full?
