October 14, 2018 at 11:02 pm
mega_kai2
SubscriberI'm using the Fields Calculator in Ansys Maxwell 3D and I can find the maximum position at which a fields-quantity occurs (i.e. I get a x, y, z position with respect to the global co-ordinate system). Is there a way in which I can convert this x,y,z vector to a point in the fields calculator that does not require manually creating a point at position (x,y,z)?
The reason I would like to do this is because the fields calculator allows me to find the maximum field quantity (e.g. B-Field) at a certain point, but it only gives me the magnitude, however I require the x,y,z vectors.
- Maxwell, HFSS or Q3D?
- Error
2620
2098
1323
1110
461
