Ansys Products
Ansys Products
Ansys Maxwell Induction motor fault modeling
    • Aioub SAI
      I am a student working on fault detection in induction motors, I'm new to ANSYS  Maxwell. Iwant to simulate the response of the motor under various faults such as "stator short circuit", "broken rotor bars", "Bearing faults" etc.
      I don't know if Ansys Maxwell or Ansys MotorCAD provide the flexibulity to introduce these faults in the motor design.
      Thanks in advance, any help in clarifying this is much appreciated.
    • Harinath Vudumula
      Hello Aioub SAI,
              You can do this analysis using Maxwell 2D/3D.
      Stator side faults:
      You need to change excitation type to external for stator windings. Create a Maxwell circuit. In maxwell circult, connect windings(star/delta) through controlled switches(as per your analysis). You can operate these switches as per your requirement (short/open ckt faults).
      Broken rotor bars:
       You need to assign each rotor bar to winding and excitation type as external. Create a Maxwell ckt. connect rotor bar winding through controlles switches to end ring parameters as shown in fig.
      you can open the switch at a perticular time instance.
      Thank you.
    • Aioub SAI
      Hello Harinath Vudumula,
      Thank you for the clarification. I have a student license for now but it's limated, I can't do the transient analysis. What kind of license can I demand for this and how much would it cost me, knowing that it's for me individually not for the university.
      Best regards
    • Harinath Vudumula
           The type license that you would required depends on the actual application you would be working on. In order to take forward, please share details related to the region, where you are located. We will pass on this information to the consern team members.
      • Aioub SAI
        I am located in morrocco north Africa, I am working on fault diagnosis in induction motors. I think Ansys maxwell is enough for this type of application.
    • steve diaz
      Hello
      ANSYS Maxwell is a powerful electromagnetic field simulation software that can be used to analyze the performance of electrical machines, including induction motors. While it may not provide direct capabilities for modeling specific faults in the motor, you can use additional tools and techniques in conjunction with ANSYS Maxwell to simulate the motor's response under various faults.
    • Aioub SAI
      Hello steve diaz,
      Can you give me examples of additional tools and techniques that can be used in conjunction with ANSYS Maxwell for fault diagnosis. I can only think of Matlab/simulink.
      Thanks
    • Harinath Vudumula
      Hello Aioub SAI,
      Please use the below link and fill the details as shown in fig. Ansys sales team will contact you from your region.
         Contact Ansys | Connect with us today
      • Aioub SAI
        thank  you Harinath.
    • rosa bella
      Even though it took me a while to read through all of the comments, I found the post to be really intriguing happy wheels
    • Diana Wills
      Indeed very helpful replies.
      p4 led wall
    • Rachel Mark
      how did you find out the fault?
      uae chemical suppliers
    • mayo mayo
      Hello! How did the sales team help you solve the problem? i am also having this problem!
       Vampire Survivors
Viewing 10 reply threads
