October 5, 2023 at 9:24 pm
Hamid R
SubscriberHi everyone,
How can I download the database of electrical steel and magnet materials from the Ansys Maxwell material library? For example, Altair Flux material manager has most of the electrical steel and magnet materials, and it is available to export data to a Python file. However, I cannot import the data into the Maxwell material library.
October 6, 2023 at 7:01 pm
DELI
Ansys EmployeeHi, you can "export to library" in material "Select Definition" window, the file type is .amat( Ansys Material Library) not Python. -
October 7, 2023 at 6:29 am
Hamid R
SubscriberThank you for your answer. Is there any way to download materials for electric machines and import them into maxwell material library?
October 10, 2023 at 1:04 pm
DELI
Ansys EmployeeUsers can add their own material database to Personal or User library directories
- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3151
1680
1470
