September 27, 2018 at 4:36 pm
Arne24
SubscriberHello,
I have a problem. I would like to develop a solenoid coil for my thesis. For this I use polylines to represent the windings. The X,Y,Z positions are given as variables. If I want to change the number of turns I have to add more lines. Is it possible to add more line elements to an existing polyline without adding a new polyline and unite them togehter? If I add a new polyline then the edges intersect and there is no nice corner (take a look at the picture).
Maybe you can help me. Thanks
Kind Regards
Arne
September 27, 2018 at 6:59 pm
Peter Serano
Ansys EmployeeHey Arne - I'd suggest using the "Draw Equation Based Curve" instead of making individual polylines.
Here you can find the equations to draw a helix for your solenoid model: http://mathworld.wolfram.com/Helix.html
This way you can parameterize the equation based line to account for the overall length, diameter, number of turns, and number of line segments per turn.
Best,
September 27, 2018 at 7:08 pm
Arne24
SubscriberThanks!
I´ll try it out tomorrow and give you feedback.
September 28, 2018 at 10:49 am
Arne24
SubscriberHello,
i tried your way and seems to be a possible way for my problem. But the computing for your solution tooks a very long time.
It is still possible to add some new lines to an existing polyline? Respectively i would like to have a perfect connection (without the intersection - compare my picture) between the connected polylines. How is this possible? This is very interesting for a few other projects?
Kind Regards
Arne
- Maxwell, HFSS or Q3D?
- Error
2630
2110
1335
1110
461
