May 15, 2023 at 12:52 pm
alaa eddine zaoui
Subscribergood morning
i houp that you are doing geat
im facing a problem in the simulation
im designe a wiless power trasmiter coils and i have 2 eror
the first one is
Process '3dedy' terminated abnormally it may be out of memory or kiled by rhe user
and the second one is down below
pleas can you help me to fix this problem
May 17, 2023 at 8:52 am
Reshmi Raghavan
Ansys EmployeeHello,
Please find the reply below.
- Process '3dedy' terminated abnormally it may be out of memory or kiled by rhe user
- Please check the RAM utilization during the simulaiton, the error can come up if the memory usage is on a high.
- Current leak to the air
- please check if there is any intersection within the conduction path.
- non model one of the coil and do the simulation considering other paths to first identify which part is creating the issue, then check the gemetry of the identified part
Thank you
- Maxwell, HFSS or Q3D?
- Error
5454
3419
2473
1310
1022
