June 17, 2019 at 11:25 pm
kevm123
SubscriberHi,
For ANSYS Maxwell I have only been able to get an object to move in a single direction for translational motion. Does anyone know how to get an object to move in translational motion of the form Acos(wt) i.e. in simple harmonic motion?
Thanks so much
March 16, 2023 at 2:12 am
cheng tianjiao
SubscriberHello,
have you solved your problem? I meet the same problem.
Does you know how to get an object to move in translational motion of the form Acos(wt) i.e. in simple harmonic motion?
- Maxwell, HFSS or Q3D?
- Error
3648
2512
1739
1226
578
