September 23, 2022 at 9:16 am
Sherin Joseph
SubscriberI have modelled high frequency transformer(HFT) in Maxwell and obtaned the desred output by exciting with sinusoidal supply and as the next I would like to excite the HFT from inverter output. For that I have given external excitation by constructing an inverter in Simplorer and interlinking the same to maxwell. But when I simualte the same, I am not getting any desired values. Found some transients in the results.
When I gave inverter output to a load with out interfacing to HFT, it will give the desired waveform.
Can anyone help me to give an idea about any specification match is require for inter-connecting maxwell and simplorer circuits
September 28, 2022 at 8:10 pm
Howard
Ansys EmployeeHello Sherin Joseph,
Could you build dataset for the excitation with your desired waveform, to simulate the Maxwell model? to make sure if the Maxwell model is good for the HFT simulation.
HDLI
September 29, 2022 at 3:27 pm
Sherin Joseph
SubscriberI have analysed HFT in Maxwell transient solver. It worked propoerly in transient solver with the sinusoidal input given by selecting Voltage excitation.
Here my problem arises when I replace voltage excitation with the external excitation. Although sinusoidal excitaion through simplorer gave desired response, when I repace that with excitation through power inverters I am not getting any waveforms (desired inputs and outputs).
I doubt some problem in power elctronic circuit interconnection to maxwell.
Can I get some tutorials for learning the same.
September 29, 2022 at 3:35 pm
Howard
My suggestion is to use dataset to build PWM waveform excitation, as similar as your inputs, to test the Maxwell model.
If your inputs is not correct in the Simplorer, please check the inverter with indutance and resistance load first. We need to seperate models to determine which part has an issue.
HDLI
September 29, 2022 at 4:28 pm
Sherin Joseph
SubscriberI worked with fourier series expression for five level invrter (120 degree mode of opearion) input and it also works proprly. But in that I didn't include PWM techniques in that inverter model, due to complexity in calclation.
Can i get any reference materials for dataset calculations to PWM wave form excitation.
Thanks for your quick respose.
September 29, 2022 at 7:29 pm
Howard
Please review the KM.https://support.ansys.com/KnowledgeResources/Solutions?solutionIdentifier=sol2052724&productName=ANSYS+Maxwell&productFamily=Electronics.
or Ansys learning hub, Maxwell getting started training, transient solver.
HDLI
- Maxwell, HFSS or Q3D?
- Error
2642
2110
1335
1112
461
