August 13, 2019 at 3:49 am
Nipuna
SubscriberWhen I'm trying to add the maxwell sub circuit to the simplorer circuit it doesn't generate details and cannot add the sub circuit saying that "You must select a design". Can you please point out me the thing that I'm doing wrong?...
August 16, 2019 at 6:46 pm
Paul Larsen
Ansys EmployeeYou didn't say what Maxwell solver you are using or what type of connection you want, so I will assume Maxwell Transient cosimulation. Please check two things. First, in Maxwell, go to menu Maxwell 2D/3D > Design Settings, and in the Advanced Product Coupling Tab make sure that the option to "Enable transient-transient link" is checked. Second, in the sub-circuit definition, you must browse to the Maxwell project, and then select the Transient design that has advanced product coupling enabled. That is the minimum requirement for connecting the Maxwell-Simplorer cosimulation.
- Maxwell, HFSS or Q3D?
- Error
2656
2120
1349
1118
461
