September 19, 2018 at 6:52 pm
sosterth
SubscriberGood afternoon.
I am encountering the following error when running Ansys Mechanical ADPL 19.1 as a non-administrative user under Windows 10:
can't create directory "unable to get value "AppData" from key "HKEY_CURRENT_USER": no such file or directory
The software works fine under an administrative account on the same machine so it seems to be a permissions related issue. Any ideas on how to resolve this? Please advise and thanks in advance!
-Sean
September 20, 2018 at 12:35 am
tsiriaks
Ansys EmployeeHi sosterth,
Login with your user account, then type %appdata% in Windows Search or Windows File Explorer Address Bar. Does this lead you to path something like C:Users
AppDataRoaming ?
Also open CMD Prompt and type
set appdata
Is this the same path ?
What about
set userprofile
is this = C:Users
If all of the above are correct/consistent, on the Windows Search box, type regedit , see if you can open this and if so, see if you can access
HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorerUser Shell Folders
and look if you have the key called AppData with value similar to above checks.
Was ANSYS installed with 'run as administrator' ? Since your username doesn't have admin rights, I would assume your IT was the one that installed it ?
Thank you,
Win
May 9, 2019 at 8:42 am
tonin
SubscriberAlthough this thread is old, the solution for this is to create AppData REG_SZ value on HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorerShell Folders with the value %USERPROFILE%AppDataRoaming
It seems that the launcher search this key instead "User Shell Folders". In VDI environments (at least with citrix xendesktop), this key isn't used in favour of "User Shell Folders", but ansys use the old key.
In a personal computer, create the key with regedit. In an VDI or SBC environment, use a GPPREF to set it for all users.
May 9, 2019 at 2:38 pm
JakeC
Ansys EmployeeThanks Tonin!
February 6, 2021 at 1:23 pm
- Workbench error
- Workbench not opening
- License Error
2630
2104
1329
1110
461
