Ansys Products
Ansys Products
Ansys Mechanical ADPL Working Directory
    • Kevin Johnston
      I'm having issues with the default directory that Ansys uses for Mechanical ADPL. Yes I am aware of launching the ADPL Product Launcher, but I want to know how it determines the default directory as I have several installations across my infrastructure and do not want to task each user to update their default working directory.
      Is there a part missed in the installation process, or can I edit a configuration file for this?
    • Aniket
      This is stored in C:\Users\anchavan\AppData\Roaming\Ansys\v231\launcherQt\profilesQt.xml file.
      probably you can programmatically edit this for everyone.
      -Aniket
      • Kevin Johnston
        That certainly helps.
        Do you know how Ansys defaults to a directory on initial startup? I'm more curious as to why Ansys was defaulting to a location that is not preset on any of our machines.
