September 4, 2019 at 3:27 pm
roubenkh
SubscriberHello Everyone
I am trying to do dynamic analysis of an electrical motor with an external circuit.
the stator has 8 poles and only 1 pole pair has winding, The rotor has 3 pole pairs with no windings. windings are simulated as rectangles on both sides of each desired pole. here is my source code. I have a problem in dowhile loop. please help me if you can.
- Maxwell, HFSS or Q3D?
- Error
2614
2092
1321
1108
459
