September 13, 2019 at 11:53 am
Silke
SubscriberHi,
I started working with Ansys Classic just some days ago. It worked fine and I already created some basic models.
Since this morning the programm freezes every time I request any kind of information from the main menu.
For example, I just defined three element types and I wanted to check them under Preprocessor>Element Type> Add/Edit/Delet. As soon as I try to open that list the program freezes and I can only close it through the Task manager.
I also saw, that a "cleanup-ansys-PCName-No." batch file is created. I'm not sure if that's normal or not, but I haven't noticed those files before the problem occured.
I restarted the PC, I uninstalled Ansys and installed it again but it's still the same problem.
Maybe I have to mention that windows requested a reboot this morning for some updates. Maybe that could be a reason?
I would be very happy to get some help with this!!
(I downloaded the student version 2019 R2.)
Thanks in advance
November 21, 2022 at 11:29 am
Pavlina Kruzikova
SubscriberHi,
This is a long shot since it has been a while since your post, but did you find a solution to this? I'm having the same issue.
Thank you, Pavlina
- Workbench error
- Workbench not opening
- License Error
2656
2120
1347
1118
461
