Platform
Platform
Ansys Mechanical crash
    • Wai
      I have tried to use Ansys workbench to do a composite tank analysis.
      So here is what I did.
      I input the composite vessel model to spaceclaim and extract the surface. Then I have those ply and rosette setup in the acp pre. Then I move the shell model to static structural. After I set all the pressure and support and generate result for deformation. When the progress come to 100%, it crashed, and when I want to restart it again, it shows below error. I used the shell model, since I cannot run parameter set when I use solid model.
    • Aniket
      This could be due to corruption of mechdb file that you have, can you please google "Corrupt ANSYS Mechanical Database? You Might Be Able to Recover" see if this helps?
      -Aniket
