ANSYS Mechanical giving inconsistent soultions
    • benlolzcome
      Hi there, I'm doing a simulation of a part, in which i want to see the stress and extension. I did the simulations 2 times and with the exact geometry, but comes out different answers, with very wide margins. The boundary conditions are exactly the same, the no of elements are slightly different (I also dint know is this a bug or some random causes).
    • Kai
      Did you turn on large deflection (under Analysis Settings) for both models? n
    • benlolzcome
      no, i did not know that option existn
    • benlolzcome
      I suspect that this is bug, because my friend encountered a similar problem, where he did the exact same boundary conditions, but has an error stating internal solution limit reached.n
Viewing 3 reply threads
