Ansys Products
Ansys Products
Ansys Mechanical Interface couldn’t open
    • sujeetpal47
      Hello Ansys,
      Today i download Ansys 19.0 from Ansys website. when i used workbench for project work, first i upload geometry from PTC Pro-E 5 in .asm format and then i try to open model but i show the error.
      What should i do and how can i solve that problem?,  help me
    • pgl
      The ANSYS Student license does not include the CAD Geometry interfaces to import directly.
      Instead, you click on Geometry to launch SpaceClaim, then you can open the Pro/Engineer *.asm file from SpaceClaim.
      If you have any issues with the file import you can also export a neutral file from Pro/Engineer (like a Parasolid) and then Open that file in SpaceClaim.
    • sujeetpal47
      Thanks pgl
    • sujeetpal47
      it again show the same error, i convert the file *.asm into *.igs format and i open the file into spaceclaim and save the file into *.scdoc format and upload into ansys workbench but it still show the same error, please help me.
      i install the Pro/Engineer into C drive and Ansys 19.0 into D drive, so this can we the reason  behind that error?
Viewing 3 reply threads
