ANSYS Mechanical not starting
    • Vivek Kurup
      Hi, I am unable to open the model in mechanical. I get the following error.
    • Ashish Khemka
      Hi Vivek,
      This error occurs mostly when a file is corrupt. Can you try using a new project and then see if the issue occurs again?
      You can also recover the corrupted project via the .mechdb files:
      In your project folder, there should be an SYS.mechdb file for each Analysis object that was on the schematic ( the location for .mechdat is indicated in error message). - Make a copy of SYS.mechdb to another folder Rename the copy to SYS.mechdat Create a new Project. File > Import change the extension filter to .MECHDAT Browse to the SYS.mechdat and open. Save the project to a new name/folder when you are done.
      Also, please avoid having spaces in the file name. This may sometimes cause errors.
      Ashish Khemka
