November 27, 2017 at 9:09 pm
big man on campus
SubscriberHello,
So I am working on a project where we are using ANSYS 18.1. The project asks for us to examine a coffee table that is constructed from a composite material. The composite material is a MDF material that is in between two red oak layers, the red oak layers are orthotropic and can be applied in more than one layer. The first part of the problem is to determine the minimum thickness of the red oak layers in order to satisfy deflection constants on the material. The other part of the problem is to examine in the fibers of the red oak was oriented by 45 deg. The first part of the problem was easy for me and I had no issues. The part that I am having trouble with is orienting the fibers such they are at 45 deg. I am using ANSYS Work bench. If anyone has any tips or ideas on how I can approach the problem please let me know. I attached the problem statement.
Thank you
December 24, 2017 at 5:53 pm
jonnyflowers
SubscriberUse ACP and post to create composites. You can then orient all your layers and apply the relevant thicknesses
December 27, 2017 at 4:33 pm
SubscriberThis ACP tutorial is on 18.1.
January 28, 2020 at 3:35 pm
SubscriberMechjegdeesan, please copy your post above and start a New Discussion, then delete the post above. That way, you will be notified when you get replies because you will own the discussion.
January 29, 2020 at 4:01 am
mechjegadeesan
SubscriberThank You
2120
1345
1118
461
