ANSYS Mechanical RDOF Calculation
    • Sbr_Ayydız
      I try to do a hormonic analysis of two beam they are connected in plane. Since I want to system have 2 translational (x and z) and 1 rotational (rot y) freedom of nodes, I used beam elements and used nodal displacement and rotation properties to constrain the model.
      I connect two beams by spring elemets via their vertex (direct attachment). Since i want to measure the RDOF-y
      • I created remote points on both 2 vertex
      • I used the below command to obtain RDOF- y
      *cfopen,'hjxkQ_rot_y_FRF_A','txt'         ! create a text file
      *do, i, 1, 5000                ! the solutions intervalls from the analysis settings
      set,1,i,,AMPL
      *get,my_freq,ACTIVE,,SET,FREQ
      my_rot_y=ROTY(measure_pilot_s)
      *vwrite, my_freq, my_rot_y
      (F8.0,g16.5)
      *enddo
      *cfclose
      set,list
      So i wonder that is the way true or not ? are the results reliable?
    • Sbr_Ayydız
      Pls, helpn
    • Rahul Kumbhar
      The script appears to be correct. I dont see any issue in the script.n
