August 8, 2023 at 3:48 pm
Teja Dolzycki
SubscriberHi I always get the error that AnsysWBU.exe encountered a problem when I try to solve a static-mechanical model.
I am using the 2023 R2 student version.
I have reinstaled Ansys several times using admin rights.
I start workbench as admin.
I've tried creating several simple models using tutorials, but allways get the same error as above when trying to solve.
Also I've tried Opening CMD as admin and typing:
regsvr32.exe ole32.dll
regsvr32.exe atl.dll
regsvr32.exe oleaut32.dll
regsvr32.exe scrrun.dll
regsvr32.exe jscript.dll
regsvr32.exe vbscript.dllas well as renaming the Ansys folder in %temp% and %appdata%.
I am using Windows 10 Pro with:
AMD Ryzen 5 3600X 6-Core Processor, 3800 MHz, 6 Kern(e), 12 logische(r) Prozessor(en),
NVIDIA GeForce RTX 2080 SUPER, (newest drivers installed)When analysing the diagnostic file I get:
******************************************************************************** ** Exception Analysis ** ********************************************************************************Failed to request MethodData, not in JIT code rangeKEY_VALUES_STRING: 1Key : AV.DereferenceValue: NullPtrKey : AV.FaultValue: ReadKey : Analysis.CPU.mSecValue: 8749Key : Analysis.Elapsed.mSecValue: 10372Key : Analysis.IO.Other.MbValue: 1Key : Analysis.IO.Read.MbValue: 1Key : Analysis.IO.Write.MbValue: 3Key : Analysis.Init.CPU.mSecValue: 906Key : Analysis.Init.Elapsed.mSecValue: 172459Key : Analysis.Memory.CommitPeak.MbValue: 1009Key : CLR.BuiltByValue: NET48REL1LAST_BKey : CLR.EngineValue: CLRKey : CLR.VersionValue: 4.8.4644.0Key : Failure.BucketValue: NULL_POINTER_READ_c0000005_Ans.Addins.AnsysSolverCOM.dll!UnknownKey : Failure.HashValue: {e42eed70-1967-a50c-8de2-2340605ed18c}Key : Timeline.Process.Start.DeltaSecValue: 267Key : WER.OS.BranchValue: vb_releaseKey : WER.OS.VersionValue: 10.0.19041.1Key : WER.Process.VersionValue: 23.2023.149.1FILE_IN_CAB: AnsysWBDumpFile.dmpCONTEXT: (.ecxr)rax=0000000080004005 rbx=000000003538ded8 rcx=0000000000000000rdx=000000003538dd30 rsi=000000003538ddc8 rdi=0000000000000000rip=0000000023d1d727 rsp=000000003538dd00 rbp=000000003538dd70r8=000000003538ded8 r9=0000000000000000 r10=0000000000000180r11=000000003538de70 r12=0000000000000000 r13=000000003538df48r14=000000003538df38 r15=0000000000000000iopl=0 nv up ei pl nz na pe nccs=0033 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00010202Ans_Addins_AnsysSolverCOM!DllCanUnloadNow+0x3fc657:00000000`23d1d727 488b01 mov rax,qword ptr [rcx] ds:00000000`00000000=????????????????Resetting default scopeEXCEPTION_RECORD: (.exr -1)ExceptionAddress: 0000000023d1d727 (Ans_Addins_AnsysSolverCOM!DllCanUnloadNow+0x00000000003fc657)ExceptionCode: c0000005 (Access violation)ExceptionFlags: 00000000NumberParameters: 2Parameter[0]: 0000000000000000Parameter[1]: 0000000000000000Attempt to read from address 0000000000000000PROCESS_NAME: AnsysWBU.exeREAD_ADDRESS: 0000000000000000ERROR_CODE: (NTSTATUS) 0xc0000005 - Die Anweisung in 0x%p verwies auf Arbeitsspeicher bei 0x%p. Der Vorgang %s konnte im Arbeitsspeicher nicht durchgef hrt werden.EXCEPTION_CODE_STR: c0000005EXCEPTION_PARAMETER1: 0000000000000000EXCEPTION_PARAMETER2: 0000000000000000STACK_TEXT:00000000`3538dd00 00000000`23d57489 : 00000000`8223da00 00007ffc`3430f05b 00000000`3538ded8 00000000`3cf97920 : Ans_Addins_AnsysSolverCOM!DllCanUnloadNow+0x3fc65700000000`3538dda0 00000000`23d69d4f : 00000000`3538ded8 00000000`00000000 00000000`5f592c40 00000000`5f592c40 : Ans_Addins_AnsysSolverCOM!DllCanUnloadNow+0x4363b900000000`3538dea0 00000000`23d6ae9c : 00000000`3538dff8 00000000`00000000 00000000`00000000 00000000`3538e0a9 : Ans_Addins_AnsysSolverCOM!DllCanUnloadNow+0x448c7f00000000`3538e050 00000000`23c07111 : 00000000`00000000 00000000`820c8d30 00000000`820c8d30 00000000`00000001 : Ans_Addins_AnsysSolverCOM!DllCanUnloadNow+0x449dcc00000000`3538e110 00000000`23e4f9c0 : ffffffff`ffffffff ffffffff`ffffffff 00000000`820c8d30 00000000`24039004 : Ans_Addins_AnsysSolverCOM!DllCanUnloadNow+0x2e604100000000`3538e830 00000000`23d79d1b : 00000000`656f9c50 00000000`656f9c50 00000000`00000000 00000000`820c8d30 : Ans_Addins_AnsysSolverCOM!DllRuntimeRegisteredCoClasses+0xbd59000000000`3538eba0 00000000`353a6780 : 00000000`3538eda0 00000000`65140e68 00000000`65140e68 00000000`3ff7c060 : Ans_Addins_AnsysSolverCOM!DllCanUnloadNow+0x458c4b00000000`3538eef0 00000000`353a89a1 : 00000000`3cf97b80 00000000`3063d748 00000000`650ec830 00007ffc`369f5ba1 : Ans_Simulation_VControllerCOM!DllRuntimeRegisteredCoClasses+0x57c000000000`3538f850 00000000`3539f35f : 00000000`65e2f2f0 00000000`00000000 00000000`30c33a38 00000000`3ff7c378 : Ans_Simulation_VControllerCOM!DllRuntimeRegisteredCoClasses+0x79e100000000`3538fb00 00000000`3539f022 : 00000000`00000001 00000000`3538fbe0 00000000`00000001 00000000`313e0000 : Ans_Simulation_VControllerCOM+0xf35f00000000`3538fb60 00000000`3539d4ce : 00000000`3ff7c060 00000000`00000000 00000000`65e2f2f0 00000000`082c8270 : Ans_Simulation_VControllerCOM+0xf02200000000`3538fc10 00000000`322aa681 : 00000000`31077020 00000000`00000000 00000000`005f5ac8 00000000`005f5ac8 : Ans_Simulation_VControllerCOM+0xd4ce00000000`3538fec0 00007ffc`351f7614 : 00000000`00000000 00000000`3f6b1fe0 00000000`00152f50 00000000`3fdb8438 : Ans_Simulation_FAManagerCOM!DllRuntimeRegisteredCoClasses+0x7fc100000000`3538ff30 00007ffc`36a226b1 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : kernel32!BaseThreadInitThunk+0x1400000000`3538ff60 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : ntdll!RtlUserThreadStart+0x21SYMBOL_NAME: Ans_Addins_AnsysSolverCOM+3fc657MODULE_NAME: Ans_Addins_AnsysSolverCOMIMAGE_NAME: Ans.Addins.AnsysSolverCOM.dllSTACK_COMMAND: ~63s; .ecxr ; kbFAILURE_BUCKET_ID: NULL_POINTER_READ_c0000005_Ans.Addins.AnsysSolverCOM.dll!UnknownOS_VERSION: 10.0.19041.1BUILDLAB_STR: vb_releaseOSPLATFORM_TYPE: x64OSNAME: Windows 10IMAGE_VERSION: 23.2023.149.1FAILURE_ID_HASH: {e42eed70-1967-a50c-8de2-2340605ed18c}Followup: MachineOwnerI'd really appriciate some help. I've been trying all day to get Ansys to run and solve tht error but no solution I've tried worked.
ThanksTeja -
August 9, 2023 at 1:56 pm
Mike Rife
Ansys EmployeeHi Teja
Try turning of Hyperthreading, AMD may use a different term, in the BIOS the try again. While there make sure nothing is over/under clocked. Once done you may want to stress test the system with something outside of Ansys like the Prime95 stress test: https://www.mersenne.org/download/#stresstest
Mike
August 9, 2023 at 3:29 pm
Gary Stofan
Ansys Employee0xc0000005 is related to permissions or some type of restriction.
Exception code c0000005 is the code for an access violation. That means that your program is accessing (either reading or writing) a memory address to which it does not have rights.
Are there any sort of virus scan or endpoint protections programs active?
August 10, 2023 at 10:44 am
Teja Dolzycki
SubscriberHi
thanks for the answers!
Sadly turning of multithreading didnt help. I let the stresstest run for 30 min and had zero issues or errors.
I only have microsoft defender running, turning that off didnt help either.
August 10, 2023 at 12:53 pm
Gary Stofan
Ansys EmployeeYou may have run across a bug 882389 when Mechanical queries Engineering Data Material names.
Can you try to install 2023R1 to see if issue is same?
- License Error
- Workbench not opening
- Workbench error
- how to open DesignModeler
- FlexNet Licensing – Not running
7742
4502
2957
1449
1322
