Ansys Products
Ansys Products
Ansys Mechanical version issue
    • uwindsorspz
      Hello Sir,
      Our lab has the academic version of Ansys. But currently, when I use the "Harmonic response" function under the workbench, it shows the node number exceeds the limitation of nodes and elements.
      Could I ask what version can satisfy this situation?
    • tsiriaks
      Please list the exact licenses that your lab has.
      Also, in some cases, you may not exceed the limit but could be due to the issues explained here
      https://studentcommunity.ansys.com/thread/mesh-size-errors-even-if-it-should-work/
      Thanks,
      Win
    • uwindsorspz
      Hello Win,
      I don't know how to check the licenses type, but it shows as the picture below.
      So could you help me to figure out what is the limitation of the node and elements numbers?
