Ansys Mechanical Workbench HPC
    • FabioCauchi
      I need to run Ansys mechanical through Workbench (need to use it in FSI later). For now i'm just trying a simple tube bending simulation as a test in ansys workbench using a static structural module to setup.
      On my desktop it runs fine with no errors. when i try it on the HPC it gives the following error:
      sh: ps: command not found
      sh: grep: command not found
      Framework error caught :
      Fatal error: Update failed for the Setup component in Static Structural.  Unable to update setup. Unable to write APDL input file.
      Does anyone knows hoe can i fix this please?
      Thanks in advance
      Fabio
    • Sandeep Medikonda
      I think this question can get a faster reply if it's moved to the Installation category.
      If the moderators feel the same way, can you please move it there?
    • Sandeep Medikonda
      Hi Fabio,
      Something is wrong with your OS installation/environment since the error said 'ps' and 'grep' command not found. Can you get in touch with your IT to see if they can look into it?
      Sandeep
    • FabioCauchi
      Yes I will ask IT about it and try to figure it out from there. I ll let you know.
      Thank you.
    • FabioCauchi
      Hi it was indeed n installation problem, there was a file missing. Thanks for putting me on the right track.
      Regards
Viewing 4 reply threads
