July 30, 2019 at 8:39 pm
July 31, 2019 at 10:10 am
Ansys EmployeeCheck to see what volumes are triggering the error and make sure they're valid. Do you have any very thin zones?
July 31, 2019 at 4:11 pm
grandhim503
SubscriberThanks !
Its not highlighting any volumes nor surfaces . if you don't mind how to check those errors .Yeah probably i have thin zones as well.
August 1, 2019 at 10:24 am
Ansys EmployeeIf you get a mesh don't worry about it. If you have thin zones there may be a tolerance issue so it thinks surfaces are nearly touching.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2522
2064
1279
1094
456
